Go Back   G5CLUB.net Forums > General G5 Community > General G5 Discussion
Reply
Thread Tools Display Modes
  #1
Old 06-12-2010, 09:09 PM
Bumblebee's Avatar
Bumblebee Bumblebee is offline
I can build it.
Default Supercharger Build aka Bumblebee to Yellow Jacket :)
Well starting my build thread,right now the main use of this thread will be to gather info and keep organized/parts gathering and troubleshoot and all the other fun stuff...If you have parts shoot me a Pm
Updated on 7/16/2010
Yellow=ACQUIRED PARTS
Parts List: Updated 7/3
Eaton M62 Supercharger
Supercharger Gasket
Stock LSJ Intake Manifold
Intake Manifold Bottom Mount
Intake Manifold Gasket (Part #12597855)
2.5 Bar Map/Intake Temp Sensor (on upper left of LSJ manifold)
2.5 Bar Pigtail (Part #88988320) not needed you can hard wire it from becks howto @css.net
Bosch/LSJ Intercooler Pump
Intercooler Pump Wiring Pigtail or Butt Connecters
Intercooler Pump Mounting Bracket- I will custom fab it.
2007 ss Stock heat Exchanger
Heat Exchanger Brackets
42.5# Injectors (recommended)
Injector Harness
Wideband Air/Fuel Ratio Gauge
Boost/Vacuum Gauge
Stage 2 Belt (Part# 12597993; requires one rib be cut off)
Custom Idler Pulley with Mounting Bracket
Extended Upper Radiator Hose
Coolant Reservoir Tank (Cobalt or Ion Recommend)
NGK Copper Spark Plugs (Part# LFR6A-11)
SS/SC intake
10ft. x ¾” I.D. Hose
10ft x ¼” I.D. Hose
4ft. x ½” I.D. Hose
Small and Large Hose clamps.
3 x 1/8th NPT ¼” Barb Fittings
• GM Bolts Needed
- 11516342 – LSJ Intake Manifold Mount To Block Bolts -(M8 X 1.25 x 60) (Qty 2)
- 11589214 – LSJ Supercharger to Intake Manifold Bolts (Qty4)
- 11900248 – LSJ TB To SC Bolts (Qty4)
• Standard Bolts Needed (Not GM)
- LSJ 1 Bar MAP To Intake Manifold M6 x 1.0 x 25 (Qty 1)
- LSJ Intake Manifold Mount Bracket To Intake Manifold M10 X 1.50 x 50 (Qty 1)
- LSJ Rear IC Pump Bracket To Intake Manifold Mount M8 X 1.25 X 25 –
- LSJ Front IC Pump Bracket To Rear IC Pump Bracket M8 X 1.25 X 35 – (Qty 2)
- LSJ Idler Pulley To Block M10 X 1.50 x 75 (Qty 1)
- LSJ Idler Pulley To Alternator Bracket M8 x 1.25 X 25 (Qty 1)
- LSJ Intake Manifold To Block M6 x 1.0 X 75 (Qty 2)
- LSJ Alternator Bracket To Block M8 X 1.25 X 130 (Qty 3)
- LSJ SC Bypass Valve To SC M8 X 1.25 X 20 (Qty 2)
- LSJ Lower Tensioner To Bracket M8 x 1.25 x 35
- LSJ Upper Tensioner To Bracket M8 X 1.25 x 40… not standard bolt though. Has to be metric hex socket bolt.
- LSJ Intake Manifold Bolts M6 X 1.00 x 25 (Qty 4)
___________________________________________
References:
http://www.cobaltss.net/forums/showthread.php?t=80620
http://www.cobaltss.net/forums/showt....2+supercharge
http://www.cobaltss.net/forums/showt...t=supercharger
Diagrams:
Notes:
Price reference (tFrom a cobalt ss member,its over priced, If you ask me)
SUPERCHARGER WITH 10K $300
INTAKE MANIFOLD WITH 10K $250
INTAKE MANIFOLD GASKET NEW GM $40
60# INJECTORS NEW OTTP $159.99
FUEL INJECTOR HARNESS NEW OTTP $30.00
2.8 MODULAR PULLEY SYSTEM NEW OTTP $90.00
OTTP LARGEST HEAT EXCHANGER NEW $175.00
IC PUMP NEW OTTP $115.00
NEW GM BRACKETS FOR THE IC PUMP $100.00
NEW GM COBALT S/C BELT TENSIONER $212.00
GM NEW IDLER $40.00 $20
GM STAGE 2 BELT NEW $49.99
NEW LSJ GM THROTTLE BODY $120.00 $100
NEW GM THROTTLE BODY PIGTAIL $90.00
NEW INJEN COLD AIR INTAKE FROM SUMMIT $256.00
ALL NUTS BOLTS AND MISC FROM GM AROUND $150-$200
Current Build figures.
6-21-2010
Did some more clean up today, and welded in the dual pass mod on the end plate...
I may just paint the ribs yellow and leave the base metal and hit it with some clear.
Before
mid way
well still not building waiting and waiting for parts to come in...but it gives me time to make things nice....restored the lsj throttle body, final pic will be uploaded tomorrow.
before
after
7-3-2010
Intake Clean up
Intake came in, seller didnt mention the condition, o well it was $30, came with a crappy dry flow, Im going to replace it with a oiled k&n.
Before
Prep
After
7/5 little detail work on the throttle body
__________________
  #2
Old 06-12-2010, 09:11 PM
chrisdordon's Avatar
chrisdordon chrisdordon is online now
Busted.
Default
good luck mate
__________________
K&N Drop-In/Bosch Platinum+4/Painted Interior Trim/R1 Concepts Drilled-Slotted Front Rotors/Hawk HPS Ferro-Carbon Pads/Intake Resonator Delete/Pioneer 3200UB Deck/SS Spoiler/WeatherTech Rain Guards
  #3
Old 06-12-2010, 09:16 PM
toolman's Avatar
toolman toolman is offline
Default
"yellow jacket" would sound a bit more intimidating than "hornet".
Good luck with the build!
  #4
Old 06-12-2010, 09:21 PM
TommyB681's Avatar
TommyB681 TommyB681 is offline
G5 post whore
Send a message via AIM to TommyB681
Default
haha very nice pic. are you getting a kit or are you gonna piece it together yourself
__________________
-Tom
  #5
Old 06-12-2010, 09:36 PM
Bumblebee's Avatar
I can build it.
Default
Indeed! lol thanks!
Quote:
piece it together, Cheaper
__________________
  #6
Old 06-13-2010, 12:14 AM
Nighthawk243 Nighthawk243 is offline
G5er that needs a life
Default
Just a note: The 03 Terminator cobra uses the same H/E pump we do, so if it is cheaper at the Ford dealership, then get it there (Unless you want a used one).
__________________
GM Stage II | 2nd Gen Projectors | 5000K Low Beams | 3000K HID Fogs | LED Tails | SS/TC Seats
▲RIP 2007 G5: Totaled 1/26/10▲
  #7
Old 06-13-2010, 12:22 AM
Bumblebee's Avatar
I can build it.
Default
Quote:
cool, thanks for that!
__________________
  #8
Old 06-13-2010, 03:56 AM
Cherry GT's Avatar
Cherry GT Cherry GT is offline
Sooooooo Much Fun !
Default
Cool Thomas
__________________
...CHERRY'S PICS...
Sometimes I know, Sometimes I don't !
Prius economy, V8 Power !
  #9
Old 06-13-2010, 04:41 AM
1cleanG5's Avatar
1cleanG5 1cleanG5 is offline
Wide Track Pontiac
Default
good luck man.
__________________
Sept ROTM 09
http://www.g5club.net/forum/showthread.php?t=9276
  #10
Old 06-13-2010, 10:25 AM
dman090 dman090 is offline
G5 regular
Default
good luck man!
__________________
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
