G5 2.2 Ecotec Dyno (before and after) Tifecta Tune
G5Club.net is the premier Pontiac G5 Forum on the internet. Registered Users do not see the above ads.
+ Reply to Thread
Results 1 to 3 of 3
Thread: G5 2.2 Ecotec Dyno (before and after) Tifecta Tune
  1. #1
    G5 n00b SF_Law's Avatar
    Join Date
    Mar 2012
    Location
    Davie, FL
    Posts
    41
    Default G5 2.2 Ecotec Dyno (before and after) Tifecta Tune
    As you can see below the Wheel Horsepower of a 2.2l (L61) G5 is 144.21 WHP and 143.45 Torque after these mods:
    Injen Ram Air Intake (now Cold Air Intake)
    OBX Headers welded to a
    High Flow Cat welded to a
    2.5" Exhaust welded to a
    Custom Sport Muffler
    I also waited to use the Trifecta tuner so the difference would be recorded. You can see that the tune added about 2WHP and about 3TQ. But the biggest difference is how smooth the A/F ratio is. The engine was running leaner with less HP and was sporadic. After the tune it was much more fluid.
    One thing I loved about this was how the Naturally Aspirated Engine almost sounds like it has a blow off valve. "Cool Beans" -Trixie
    Here are a couple of videos of the run as well.
  2. Remove Advertisements
    Pontiac G5 Forum
    Advertisements
  3. #2
    G5 n00b
    Join Date
    Dec 2012
    Location
    'merica and Canadia
    Posts
    34
    Default
    curious as to what the baseline (stock motor) run was
  4. #3
    G5 addict C.R.A.V.3's Avatar
    Join Date
    Apr 2011
    Location
    Laredo,TX
    Posts
    1,807
    Default
    Im curious what hp my LAP 2.2 has
    Sent from my SPH-D710 using Tapatalk 2
    ▼C.R.A.V.3▼
+ Reply to Thread
Visitors found this page by searching for:
2.2 ecotec tune
2.2 ecotec dyno
Ecotec Engine Tuning Modifications
ecotec header dyno
ecotec 2.2 tune
ecotec 2.2 dyno
ecotec na dyno 2.2
trifecta tune 2.2 ecotec
2.2 ecotec tuningtrifecta ecotec dyno2.2 ecotec whphow to tune a 2.2 ecotec2.2 ecotec horsepowerwhat is the stock wheel hp of a 2.2l ecotecEcotec trifecta tuneHp of 2.2 ecotec with intakel61 ecotec header review2.2 ecotec trifecta tunehow much horsepower does a injen cold air intake add to ecotec2.2 ecotec dyno graphg5 ecotec 2.2 partsna 2.2 ecotececotec tsudo header picturesstuff for 2.2 ecotec2.2 ecotec headers dyno
SEO Blog
Tags for this Thread
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
