I ordered the 2.4 intake manifold and gaskets 2 days ago and wonder if I should just port out my existing 2.2 TB or get a 2.4 TB? How much bigger is the 2.4 TB? If I have an 07 what year model 2.4 TB would hook straight up and does anyone have part #s? Any info at all is appreciated. I'll post a how to on the manifold swap if there isn't one already too.
Discussion Starter · #2 ·
I have found out that the 2.0 TB is bigger than the 2.4 TB but it seems that the 2.0 TB would take a lot more modifications. The 2.4 TB though requires a tune.
I believe the 05-07 2.4 TB are 8 pin and
08-present TB are 6 pin.
I hope I'm right about the different pin for the year models because this is the main factor for hooking up with little modification.
2+2= <*)))><
Would you like for me to go see how many pins my TB pigtail has?
And the 2.0 TB would be overkill. Unless you're moving a lot of air with a supercharger/turbo, you won't need it.
That would be nice to see how many pins yours has seeing you have a 07 2.4.
Mine is an 07 2.2 and I will be getting my 2.4 manifold soon.
