1 - 7 of 7 Posts
2008 Pontiac G 5
now ac keeps Shutting Off but if u take the battery cable off wait 10 15 sec Then put it back on it works again I can’t take this heat please help!!!!
2008 Pontiac g5 Oklahoma City area
PLEASE HELP!!!!!
System fully charged? Small structure on cooling fan frame, bottom driver side present? Mine had rusted away, causing no a/c when all else was good.
2008 Pontiac G 5
It works if I take the battery cable off but only sometimes it shuts off then have to take cable off again 🤦🏼‍♀️🤷🏼‍♀️
Evidently, the computer doesn't like what it sees comma and disables it, yet does not throw a code. Disconnecting the battery resets the computer making it forget whatever was wrong.
Sounds like something is shorting out. I'd test the fuse that goes to it (probably wont do much, or be the problem), but it's cheap and fairly easy to check. It could be the condenser. Not sure if these cars have driers installed in the A/C lines. It could be that, but I'm at a loss for ideas about what this could be.
1 - 7 of 7 Posts
