Replaced cv axle due to clunking by the transmission. Got the new one in and there is still clunking when going over bumps. Jacked it up, pulled the tire off and by hand im able to move inner axle slightly by the transmission. Not able to pull it off but able to wiggle and recreate the noise. Cv clicked and seated in when i installed it so i dont think its a clip issue. Any ideas?
Dunno if you resolved this yet but,
Did you change the Inner Stub Axles when you did the new CV axle or install the old ones? If its only alittle bit of play then I'd not worry about it, but its probably just normal wear on the clip that holds it in thats letting the bit of play and making your noise
