21 - 40 of 47 Posts
Discussion Starter · #22 ·
Yeah, she's just looking for you two.:) Mona has it done it yet, but it hasn't been that freezing so far.;)
:lol: My car's so caring! ;)
Actually, it's just a temp sensor under the hood and don't ask me where it is. I still haven't found it yet.;)
i think i remember hearing that it's some where around the passenger headlight, but i've never gone looking for it.
Yeah, when I first the car I wanted to see where it was for some reason, maybe I'll try to look for it later. Thanks.:)
Hmm... interesting where it could be mounted. I guess it'd have to be somewhere where either the engine heat or light heat wouldn't affect the result.
Yes.
It is possible to get ice on your DIC.
That's all for now kids, not go play with your headlight sensors!
*lol i kill me*
Sluts the post # 885
falkor!!!
2+2= <*)))><
I know GAS doesn't freeze easy, but if there's any water in there it can cause problems, yes?
This is true. I didn't think about that. But even if it freezes, you should have any problems unless you let the car run pretty empty. I believe the water would be at the top of the gas. Not sure as to what is denser, ice or gas.
Just did a little looking up, and gas is about 70% as dense as water is, liquid wise, so if you had water in the tank it would be on the bottom if its a liquid. And looking up the density of ice, it is about .915 g/cm3. So the ice would be on the bottom anyway. So yes, this could cause a problem.
21 - 40 of 47 Posts
