2009 pontiac g5 gt coupe
going to be lowering my 09 g5 gt this spring, planning on getting lowering springs because i just want to get rid of the wheel gap.... my question for those experienced in lowering their g5's is: do i need to replace any other suspension parts like sway bar end links or smaller struts shocks etc.... if so any recommendations on a set of springs + other parts
thanks!:)
My favorite springs are Powell Race Parts YYZ springs:
I paired them with Koni yellow adjustable shocks and struts:
I've also used the GM FE5 shocks and struts with good results. They are an improvement over the FE3 suspension parts that your G5 GT has.
Additional parts I recommend are an upgraded front sway bar (I have the GM FE5 front sway bar from a Cobalt SS/SC) and a Powell Race Parts rear sway bar.
I also have Powergrid sway bar end links, solid control arm bushings (MOOG), and rotated & upgraded engine mounts, but I think the most noticeable improvements can be had with the lowering springs and swaybars.
thanks man appreciate the suggestions will def be looking into those upgrades
My guy, get the Ksport Kontrol Pro coils for the cobalt SS, I have them, they fit on G5 GT's just the same, and you can adjust your height. Mine ride rough but I haven't touched the damping at all, and the fitment is absolutely perfect. Couldn't be happier, and for $850, its a deal.
