Heres my how-to on disassembling the dashboard to gain access to the radio.
First you need to pull out one clip on the panel that is under the steering wheel (above your knees). This will help you get a grip on the silver info panel. It is the upper most right side clip.
Next you need to pull out 2 clips to remove the silver info panel. Be careful as the wiring harness is short. This is a difficult one to remove, try to pull it straight out as odd angles might destroy a clip.
Now remove the passenger side panel, 4 clips. This one is easier, again pull it out carefully due to its length.
Now for the radio bezel. Since you have removed the overlaying panels along the top right and left edges you can use a screwdriver (flat blade) to help pry the upper 2 clips out. Still be careful as you can still mark up the silver panel. Heres the clip locations (6) and how it looks once its removed.
