G
Guest
·Guest
** I DID NOT DO THIS MYSELF, I DO NOT OWN A G5 YET, THIS IS BASED OFF GENERAL KNOWLEDGE AND DOING THIS IN A DIFFERENT CAR**
*RESULTS MAY VARY**
*THIS IS NOT A "HOLD YOUR HAND" WALKTHROUGH"*
Subject: "How-To: Install an aftermarket HeadUnit"
Tools Need: Wiring harness generally it comes in the box,GM or G5 dash kit, or online. VOLT- METER!!!!!!!! Flathead screwdriver, phillips screwdriver, wire strippers, electrical tape.
Ease of Install: (Moderate)
Estimated time to install:1+ hours
For starters, I am fairly certain your engine codes are NOT stored in your Head Unit. Why would they do that?
Ok, Lets get started,
Hopefully you have bought your new headunit, if not GO BUY IT!
*Start by taking off the moulding around the stereo, I don't know how, maybe just pop it off with the flat head
* then pull the stereo out, just take a look at it, and figure it out yourself, there should be a onslaught of wires connected to a single plug that is plugged into the back of the HU. Unplug the wires from the stereo,and unplug the antenna cord.
* If all goes well, the plug from your original stereo should fit right in the new one, as well as the antenna plug.If so, plug it all in, put your new stereo in place of the old one
* Since your old stereo is roughly twice as big as your new one, your gonna have a slot there that allows people to look in your dash correct? This is where that dash kit comes into play, just slide it in, and now you have a extra place to store your shades or phone.
* If the plug doesn't fit into the new stereo thats where the wiring harness that came with your stereo comes into play.
Here are two wire color schemes that are common
Function Typical Wire Colors
Memory / Constant 12V(+) Yellow
Switch / Accessory Red
Ground Black
Illumination Orange/White-multicolored
Antenna Remote Blue
Amp Remote Blue/White-multicolored
Left Front (+) White
Left Front (-) White/Black-multicolored
Right Front (+) Grey
Right Front (-) Grey/Black-multicolored
Left Rear (+) Geen
Left Rear (-) Green/Black-multicolored
Right Rear (+) Violet
Right Rear (-) Violet/Black-multicolored
Function Color
Memory (+12v Constant) Orange
Ignition (+12v Switched) Yellow
Ground (-) Black
Illumination Gray
Dimmer Brown
Power Antenna Pink
S p e a k e r s
Right Front (+) Light Green
Right Front (-) Dark Green
Left Front (+) Tan
Left Front (-) Gray
Right Rear (+) Dark Blue
Right Rear (-) Light Blue
Left Rear (+) Brown
Left Rear (-) Yellow
**DO THE NEXT STEP ONE WIRE AT A TIME, CUT A CORD, SPLICE IT OPEN, CONNECT THAT WIRE TO THE SAME COLORED PLUG ON THE PLUG, TAPE IT UP, THEN DO THE NEXT, IF YOU TOUCH TWO WIRES TOGETHER, THERE IS A GOOD CHANCE YOUR GONNA SHORT SOMETHING.**
* your gonna have to use the wire strippers to clip each and every cord that goes into the plug. then strip then about 1/4-1/2 an inch so you can connect the new plug to the existing wires, its basically a mix n match game, all the cords should be color coded, so just match up all the cords, twist the wires together and wrap the naked wire in electrical tape. If you have extra wires make sure you havent missed anything, all the wires from the plug should be attached to a wire from the car,there may be extra wires from the car that dont have to be used, just make sure those wires arent used for anything, then tape off the ends of them.
Mount the stereo in the dash, then use the dash kit in the open space, and voila!, new stereo.
*If someone has done this before on their G5, please make sure to tell me, and I will add or change it.*
*RESULTS MAY VARY**
Ground Black
Antenna Remote Blue
Left Rear (+) Geen
Function Color
Ground (-) Black
Illumination Gray
Dimmer Brown
Power Antenna Pink
S p e a k e r s
Left Front (+) Tan
Left Front (-) Gray
Left Rear (+) Brown
