1 - 7 of 7 Posts
Tools Need: 10mm ratchet, small flat head screw driver
Ease of Install: Moderate
Estimated time to install: 1hr
Please see the link below to download a copy of TWM's install instructions
http://www.twmperformance.com/manuals/C ... Manual.pdf
I noticed in the instructions that you need to cut a plastic piece with a hacksaw. If you would need to revert the car back to the OEM shifter assembly, would you be able to use this piece in its modified condition or would you need to buy a new one?
So for someone who never does this kinda thing, you think I could install it myself based on the TWM instructions?
I'd have to have to pay some overpriced (in my area) mechanic to install install something I coulda done myself.
If the instructions look easy enough go for it. but you will have to cut a little more out the the instructions say or you wont have 5th or Reverse. you will under stand when you install it and try and put it in 5th. what i did was just kept trimming it untill i was able to.
1 - 7 of 7 Posts
