Tools Needed: 7mm Socket, Pliers, and 10 mm wrench
Difficulty: Easy
Time: 30 minutes - 1 hour
1. Using the 7mm socket, remove the outside bolts that secure the tail light
2. Using the pliers unscrew the top cargo net hook then pull back the carpeting
3. Using the 10 mm wrench remove the nut that is remaining. Then the taillight should pop out and disconnect the wiring harness
4. Now remove the wiring harness by turning each light socket till they click and pull out
5. Now remove the biggest light bulb, once removed plug in the LED plug into the light socket of the bulb you just removed
6. Now put the remaining 2 light bulbs back into place with the smallest light going into the reverse light hole
7. Now Remove the backing of the black box on the New Tail Light and place it some where in the tail light cavity where it won't be in the way of the tail light
8. Now just put the tail light back in place and replace the nuts and bolts and your done
9. Enjoy your New LED tail lights
Difficulty: Easy
