Tools Needed: See Picture Below + Paint in the appropriate colour
Ease of Completion: Moderate - Hard (Be confident in your skills)
Time to install: To ensure paint drys and sealant cures 48hrs is recommended. To separate the housing about 1 hr.
For Starters You must either:
1.Take the lights out of the car, or
2.Purchase a second set of lights...
Method number 2 is probably the preferred method but may cost a little extra, reason i got a second pair is i may change my mind, and i needed the car...
Here are some simple shots of the lights it self show there is not much to disassemble it.. the hardest part is heating up the entire housing and separating the clear cover from the housing itself.. (This can be done with a heat gun, or hair dryer)
I first removed all the lights and connections as well as the rubber sealant for the main high/low beam.
Basic tools are needed, Hairdryer (my choice), some people use a heat gun, but i didn't want tooo much heat created, a 1/2
extension, a few small straight screw drivers, two sharp blades
You somehow have to heat up the entire Headlight assembly, i took the hairdryer and aimed it into the back of the high/low beam hole, and held it there for a while, even while i was prying apart the housing from the clear plastic i left the hair dyer in there so that it never hardened back.
after separating the Housings i started by separating the case itself from the chrome surroundings to be painted, there are 3hex screws on the back of the housing to be removed.
now with the hex screws out the reflector piece should come out.. and now you can remove the turn signal and side marker orange reflector..for the turn signal i used the 1/2 socket extension to push out the orange reflector.
for the side marker i just used the trusted old fingers (no special tool required) to pop out the lens
with everything disassembled it should look something like this
now that everything has been disassembled the hard work stars (yeah get ready for alot of beers and many headaches) tools for the job as well as i tired a dremel for a bit, but it heated up the sealant and then cause the dremel is going so fast it shot hot (i mean HOT) sealant everywhere....
Scrape as much of the sealant away as possible, it will probably get to the point where you cant take any more and just give up and say its enough, well it probably is, just use alot of silicon when sealing back up again...
you should try and get as much off as possible in order to ensure a correct seal when you put everything back together (no leaks)
i taped off all areas that i didn't want the paint to go, inside the turn signal and around the high/low beam.... with painters tape (less sticky, and does not leave any residue when removing after painting has dried)...
now when putting it all back together just reverse the disassembly procedure but remember you need to go get orange bulbs instead of the clear OEM bulbs... and when sealing black sealant is what I intended on using but my Anus of a father used my caulking with out asking and i had to use clear stuff from my work van (little hand held bottle of it, i used 5 in total to do it all, may seem like alot but there was a lot of waste, i was not about to shit my pants trying to squeeze out the last drop of caulking) for the finished result put back in car , and enjoy.
