1 - 2 of 2 Posts
I have a 2007 pontiac g5, my alarm control battery died so I replace it with a new one now I have to reprogram the control but I have no idea how to do it , i've searched online but havn't found anything. hopefully someone can give me instructions on how to reprogram the remote
Thanks !
I'm not quite understanding. I think you are talking about your key fob that you use to lock and unlock your doors and open your trunk. It sounds like you changed the battery, but it still does not work. Just an FYI, changing the battery does not cause it to lose its "programming". If it still does not work after changing the battery, you may need to replace the remote. If you are mechanically inclined, you can check out the repair how-to that I made.
1 - 2 of 2 Posts
