Replaced all four injectors a short time ago. Long time fuel trim came back down around low single digits. Yay! It was headed up (on the negative side), and was probably close to throwing a code. Only thing now is, when cold, and I blip the throttle, there's no 'instant enrichment' and the car stumbles for a half-second. Is there a 're-learn' the ECM needs to do? Maybe need to burp/purge the fuel rail? Those adapter cups really confused me, briefly!
I haven't changed the injectors in my car, so I don't have any experience with this. It shouldn't hurt to bleed off any air in the fuel rail. I think there is a schrader valve on the end of the fuel rail. Turn the key on to pressurize the rail and use something to push the valve stem in. It should be gasoline spraying out, not air.
I put in Siemans 60 lbs hr injectors and I had no issues after install or a relearn process.
I do think I had purged air from the rail, but not 100% sure. It was long time ago.
Yep, carefully wiped out the bores and 'adapter collars', and lightly lubed up the o-rings for re-assembly. It only happens when cold, so maybe the MAF sensor is dirty/worn. My Just simply replace it, If it's not too expensive. It's OE, to. Fuel trim numbers also do not indicate compensation for an overly lean situation.
Cleaning the MAF is super easy. It's $7 for the can (specifically for MAF cleaning) and you let it air dry for 30 minutes and put it back on.
Related Threads
G5 Club
385K posts
9.3K members
Since 2007
A forum community dedicated to Pontiac G5 owners and enthusiasts. Come join the discussion about performance, modifications, classifieds, troubleshooting, maintenance, and more!
