1 - 2 of 2 Posts
Hi all.
I got my G5 gifted from uncle with the drivers side speaker not working. Removed door panel discovered bad leaking in rainy weather (water seems to run down right on the speaker).
Checked my weather stripping all looks good.
Since I've replaced speaker only to have same issue.
Now my computer is having issues, blowing fuse and no obd. Is this related to water? Any suggestions please?
The mechanic said to get rid of car because of computer issues, but I love my car and don't want to/can't afford a new ride.
'Gremlin' the 07 G5GT (913L)
What computer issues? I thought we had fixed the OBD not reading with the cig fuse in ur other post.
If theres no holes in the door, it has to be leaking in from the weatherstripping or window stripping. Replacing the speaker with an OEM instead of a marine/waterproof speaker without fixing the leak was not a good idea. Imho using anything but a waterproof speaker on a car door is a bad call.
And no, alittle bit of water killing your door speaker wouldnt affect the ECU.
Why was it at that mechanic, What did that mechanic diagnose, and what did he say specifically?
We need alot more information than that. What else is actually wrong with the vehicle?
1 - 2 of 2 Posts
