Ok this is long but read it all.
This is just something for reference for beginners starting, those who are new to the site, or those whole are lazy and don't wanna use the search function.
Basically just a FAQ/Tutorial on lowering a Cobalt/G5 in specifics.
The only way you will get anything out of this is by reading it in full and asking questions if needed. The way of the world is trial and error as well as learning from others mistakes.
To start off, the suspension is the main thing that SUSPENDS your car in the air with the base being the wheels and tires. There are the 4 points that touch ground. Suspension arms, struts, springs, shocks, and twist beam are all components that help keep the car up off the ground/road. These parts are also controlled so the inside components of the car (aka you and the passenger(s) are not shaken nutty.)
This post will cover a few points that are now frequently asked and give explanations and or proof in form of logic, or quotes.
Starting off, WHAT SHOULD I CHOOSE? WHATS THE BEST?
Firstly, BEST? Drop that word from you vocab. Seriously, Obviously, what's best.
