not all 3 parts. only the top 2 kidneys
Are these real easy to install?
Zipties.
Anyways, to the OP: That kit is made for the G5GT, which has a different bumper than the base models. The top part will fit, but the lower part will not.
yea its relatively easy as long as u have something to cut out the plastic honey comb(if u want which i would recommend otherwise it wont look right). it said it should cut easy but for me it did not. i ended up using a dremel tool which worked nicely for cutting and then smoothing out the edges.
