1 - 10 of 10 Posts
Does anyone know if you need to buy a certain size of shifter knob for a manuel G5? Im just looking to buy one off of ebay, but i noticed some had different dimensions than others.
I believe you need an adapter or a short shifter.
Oh god ill find the one i bought. I just searched 5speed shift knob on ebay. It came with those little plastic inserts (diff sizes for diff width shifter)
Yeah set screw styles like this would work.
I've owned two separate shift knobs that are "universal" and I would advise against buying them.
Half the time they break, or don't stay tight and fall off mid-shift.
If I were you, spend the extra money to thread the shifter yourself, and buy a new threaded shift knob (my 08 g5 is 12mm x 1.75). Then you will also need a new shift boot depending on the length of your new nob, unless you don't mind the two not connecting.
May be a bigger upfront cost, but will save you frustrations in the end, plus it looks way better.
1 - 10 of 10 Posts
