1 - 3 of 3 Posts
So today, I was cruising around doing my thing, then noticed at one point that when I shift into first gear, it sometimes catches and slighty grinds, but not enough to hurt anything. I’m taking it slow for now when I shift into first, but the rest are okay when I shift into other gears. Anyone know why this is?
Worn Syncro? Probably best to get it serviced ASAP. Play possible they can save the whole transmission and only replace the worn part. Not an expert, just moderately educated guess.
Keep in mind that you'll only be able to smoothly shift into 1st gear if you are completely stopped, or barely moving. Does it grind if you are completely stopped? It might be your throw out bearing.
1 - 3 of 3 Posts
