As the title suggests, I am having an issue where the car wont slow down when I remove my foot from the gas pedal. Once I am up to speed it acts like cruise control is on, but there is no cruise control. Maintains speed and RPM, except it will drop significantly momentarily and then go right back up to where it was when I take my foot off the gas. Occasionally is will keep RPM at 1000 or above when parking after being driven, and if I rev the engine it shoots up to 3-4000 and stays there until I put it in N and turn it off. When turning it back on immediately after, it idles just fine. Other things I am experiencing since it began is very poor gas mileage. I have done some maintenance myself: replacing the Mass airflow sensor, cleaning throttle body, new starter and some wiring that was split that caused some other trouble codes (P0102 is the only one I can remember off the top of my head, this also got rid of the hard shifting and poor acceleration) The wires I repaired were a tan one with a black stripe, a blue one with a white stripe and a solid blue one (driver side, front, near where the dipstick is).The hard shifting I was experiencing is gone and it drives very smooth now,
The above issue only appeared after everything else was done.
I tried to be as detailed as possible, if more information is needed please let me know! thanks!
